Old 12-15-2011, 02:27 PM   #4
Dale_K
The major parts stores, like O'Reilly, will test your batter & charging system for free. I have a generic O'Reilly battery in my 2000 S and it works fine. In fact, I think the old Walmart battery that came with the car was actually still good when I replaced it.
After I bought the new battery I was golden for about a month, then the new battery went dead too. You'll want to check your car's voltage. With the motor running a little beyond idle you should have around 14.3 volts measured across the battery terminals. If it's less you could have a weak or bad alternator. O'Reilly sells remanufactured alternators. They're different between manual and Tiptronic cars. Replacing the alternator is a feasible DIY but it's tougher than a "regular" car.
There are some internet threads about replacing only the voltage regulator and I tried that first but it didn't help my car. It's just as much work to replace the voltage regulator (it's mounted on the alternator body) as it is to replace the whole unit. I wish I'd have just put the whole unit in the first time because it's kind of a hard job to pull the alternator out.
Dale_K is offline   Reply With Quote
