Thread: Front Sway Bar?
Old 12-15-2011, 10:42 AM   #10
stephen wilson
Originally Posted by Mrmaddbrad View Post
That is if you're already Understeering... But it could potentially just reduce oversteer, and body roll as they are designed to do...
No, a stiffer front bar will increase understeer. The only unusual case where it MAY not, is on a high CG, front-heavy car, with poor camber control ( like a 60's muscle car ). In which case the reduced roll (and reduced positive camber), adds more to the front grip than the increased weight transfer (from the larger bar) removes . A Boxster certainly doesn't fit into this catagory.
There are plenty of books that explain the affects of weight transfer in detail.
