Old 12-14-2011, 11:10 PM   #10
Kroggers
Thank you for all the good info and help. Basically the car was delivered with the engine as stock. To save some money, I had only the minimum done to get the car approved by FIA. Figured other "improvements" could be done by me as and when I had the time and money.
I only got the car at the start of the 2011 season, so this winter is the first time I get to start looking at what I should do.
The IPD plenum was my first "upgrade", installed it last week. So "no" I have not done any tuning for the plenum - I hope to do that at some point with a DME upgrade...
I will remove the engine fan, and do some reading on how to remove the smog pump - is there an "idiots" how to on the forum I can read for this?
Where is the breather for the power steering, and how do I extend it?
Sorry for the stupid questions. I am new to the Boxster and this is the first time I have started to look at all this in detail
And, yes - cleaning the engine is on my list
-- EDIT --
OK, did some searching, and if I understand correctly I need to get the following parts from Porsche to be able to remove the smog pump:
996 113 140 53
996 113 340 50
996 113 233 50
996 113 213 51
I also need to remove the intake system to get to the parts that have to be removed and replaced.
Does this sound correct, or have I managed to get the wrong information?
Kroggers...
"Trying to drive a Boxster S for team CoolCava Racing!"
www.coolcavaracing.com | www.paulkrogdahl.com
Kroggers is offline   Reply With Quote
