Old 12-13-2011, 07:19 AM   #11
jaykay
jaykay's Avatar
Originally Posted by blue2000s View Post
I'm using Fluent in these simulations.
A Y will be more efficient than a T for airflow in a steady state, that's correct.
Keep in mind that with three cylinders to a plenum, there is a pretty much constant flow of air into the plenum when the engine is kept at a constant speed. There is always a cylinder pulling air. The pulses that influence secondary pressure waves are important, but they are secondary in nature so the influence on flow is on a much lower order than the primary vacuum pulled by the cylinders themselves.
Here are three more simulations varying on the one I posted earlier. The first one just adds a sloped wedge to the original T. The second adds a large radius to the T junction and the last one combines the radius with the wedge.
The volume flow rate results show that the T and T with wedge have almost identical flow rates. The radius-ed T with and without the wedge are both almost the same flow rates but are about 30% greater than the standard T.
Well done; well put. I was just considering any tendency to pull from bank to bank when the firing order is such that there is a strong intake pull from one side versus the other.
Looks like in theory the 'y' has some definite benefits...now comes the hard part part of testing varying shapes and geometries.
986 00S
