Old 12-11-2011, 08:10 AM   #1
ChairmanRon
Originally Posted by tonycarreon View Post
JFP's right. you have to install the stalk to actually have it show up. the older hack allowed you to "select" the item that displayed constantly. using the durametric simply enables the OBC. the display will show up once the stalk (or another means of controlling the display) is put in place.
Technically, the stalk is not required. The "poor man's" OBC hack involves installing one or two buttons into the blanks on the dash, and individually wiring them into the instrument cluster connector on the back. I didn't want to go through all the trouble of installing the stalk, so I opted for the dash buttons. Works great and took under an hour.
ChairmanRon is offline   Reply With Quote
