Old 12-10-2011, 07:17 AM   #1
tonycarreon
tonycarreon's Avatar
there is an external amplifier, but it's an additional item, not a required item as far as i know.
wayne's 101 projects book has an article on going from stock to 3rd party, so you can find some info there.
Pelican Technical Article: Changing Your Boxster Stereo Head Unit / Installing Boxster Ipod Integration - 986 / 987
Originally Posted by 101 Projects
If your car does not have an external amplifier, then the speakers for the Boxster will plug directly into the brown connector B on the back of the radio. If your Boxster has an external amplifier, then there will be a smaller yellow connector that outputs the signals from the head unit to the amplifier. If you have a factory amplifier installed, then you can simply adapt the signal from your new stereo into the leads on the yellow plug, as I have done with this stereo installation. If not, then you simply hook up the speaker leads from the new stereo to the adapter that plugs into the brown connector.
