Old 12-07-2011, 05:30 AM   #1
JoeFromPA
Feeler/Price Check: Ocean Blue 99 boxster 5-speed, 64k miles
Hi all,
I'm planning on selling my boxster in the spring but wanted to put a feeler and price check on it now for planning purposes. Figured I'd write this up now since it'll be in the garage for the next 3 months on a trickle charger and occasionally taken for a quick spin to keep it in tip-top shop. Feedback and interest are welcome.
I'm planning on asking $10k for it come ~April - with a fresh inspection sticker and full detail at that time. If you are interested, you are welcome to contact me beforehand, otherwise can anyone tell me if that price sounds right based upon the below?
Background
99 Boxster 5-speed manual with 64k miles in ocean blue metallic/savannah interior, I'll call it a 2-owner. My father bought this car in ~2003 from CarMax in Virginia with about 30k miles on it. He drove it year round for ~3 years and then started garaging it year round except for a few thousand miles driven a year on his ~100+ mile a day round-trip commute. During that time I detailed it for him and gave him maintenance directions, so I know how it was maintained/what repairs were done though he unfortunately did not keep records.
I took ownership of the car in July 2010 and have put 9k miles on it since that time. I personally performed a 60k mile service and replaced the OEM front motor mount - in 1.5 years of ownership, it's been a perfect car.
Known maintenance:
Unknown prior to my father's ownership @ 30k. At or near 30k it had a service that included spark plugs and air filter. Up to 55k, it had oil changes every 5k miles or once a year. It followed the book or better on all service intervals.
At 53k the coolant was drained and replaced by Porsche along with a new coolant expansion tank (see repairs).
At 58k, I replaced the spark plugs with parts bought off Pelican Parts. Air filter, fuel filter, serp belt, NGK spark plugs, oil change. I changed trans fluid to Mobil 1 Delvac 75w90 at 61k.
Brakes were done ~52-54k all around with zimmerman cross-drilled rotors and pads. Brake fluid was last flushed at that time - I have a bottle of ATE super blue and may flush the brakes prior to spring.
Repairs:
This boxster has been amazingly reliable. The only known repairs in 8 years of being in my family have been:
- Coolant expansion tank cracked ~2.5 years ago while my father was driving. Towed to Porsche, full inspection performed, expansion tank replaced w/ new coolant.
- The horn was going off intermittently. Porsche replaced a switch under the pass seat, which did nothing, and the horn continued to go off. I simply folded some business cards between the horn pad and steering column and it stopped going off during my ownership.
- OEM front motor mount was replaced by me with a 987 front motor mount.
Body work:
- In ~2007/2008, a branch broke off a tree and hit the pass side of the car. It somehow only broke the mirror and scratched the right fender and hood. Repairwork was done by Classic Coachwork, a smalltime chain in my area that does fine work. The fender and mirror look perfect to my eyes - though you can tell the mirror plastic is newer than the other side of the car when I haven't recently treated the exterior plastic. The hood, in my opinion, was just an "OK" job on the repaint.
- In mid 2010, road debris hit the front bumper and deeply scratched it. It was already well rock-chipped, so I had it replaced under insurance. Replacement done by Classic Coachwork. They also replaced the front grilles and some plastic undertrays - really an exceptional job. Front bumper now has 8k miles on it and looks great (albeit still with 1-2 rock chips already).
Side note: front radiators were cleaned out during front bumper replacement. Really not bad at all.
Known issues:
- The horn stopped working last month. It's most likely just the fuse.
- Leather seats show wear at bolster. It's not bad, but it's there
- Shift boot is worn.
- Vert. top fabric looks good and plastic is mostly clear, but the fabric is very slightly coming unglued at the very rear bottom. You can slip a pinky through it if you lift it up and try. Still sheds water properly, etc.
- Wheels have slight scuffs on them. Hard to see from more than 5 feet away.
Modifications:
- Litronics installed ~2007
- At 52k miles, bilstein HD struts installed along w/ front and rear strut braces. Provide a firm, planted ride - improved even from the OEM boxster in terms of handling.
- 18" turbo twist wheels shod in michelin pilot sports, 60-70% life left.
- De-snorkeled
- Zimmerman cross-drilled motors
- Spin-locks for hard-top are installed. Sold the hard-top
Summary:
Great inexpensive driver's car. Revs out beautifully, handles like a dream, stops on a dime. History of being very reliable (even moreso for a 12 year old german sports car!). Not a show car, but always ready to drop the top and blast through back roads for an hour or a weekend. It's been a wonderful car to myself and my family, well cared for, and is now time to go due to the need to drop my coupes and get a 4-door.
The boxster freshly washed
Old motor mount out, being replaced by 987 version
Spark plugs that came out 6k ago
Joe
99 Boxster 5spd - 64k miles
06 Civic SI - 114k miles, D.D., unbelievably reliable and fun to beat on everyday.
08 Legacy GT 5spd - 74k miles.
JoeFromPA is offline   Reply With Quote
