Originally Posted by Burg Boxster
You need to keep the panel or remove entire set up as the h/u and amp are dependent on it being there. That said, there is plenty of room in the center console so you could just bury it in there and leave it permanently set to the most (of the choices) desirable sound setting. You might be able to eliminate it completely if you replaced your amp w/ one from a M490 set up (I have a spare 4x40 one if you are interested) and possibly switch a few wires around. See the sound system schematic for details.
Good luck
Thanks! I am not familiar with the M490 set up. Was the this the Bose system that replaced the DSP? I would be interested in your amp if it would allow me to remove the DSP. I can't bury it as I will need the space back there. I have the factory speakers in the storage box though. I believe there are four little speakers back there...so that would be 8 speakers to drive.
I don't find the DSP to be very good..
