Old 12-04-2011, 02:38 PM   #1
crumbum
DIY Transmission Rebuild?
I have the typical 2nd gear synchro issue on my 2000 Boxster S. When I bought it, I (regrettably) did not do a PII and overpaid too. Yes, I can analyze the things I SHOULD have done, but I am trying to look forward on how to get us much enjoyment out of my purchase.
I have already done some work on it myself (water pump, radiator, short circuit repair, transmission fluid, oil and filter) which chewed further into the $$$.
The only nagging issue that I am now aware of is this 2nd gear grinding. I have figured out that I can double-clutch (up) into 2nd without the grind. However, that doesn't make for sporty shifting (at least not how I double-clutch) and also doesn't work well for shifting down for a turn.
Is it possible to do a DIY repair on the 2nd gear synchro? Are there step-by-step details available on how to do it? I have seen instructions for other transmissions (below), but not for the Boxster 6-speed. Any help?
How-To: Porsche 915 Transmission Repair Tutorial Part 3 - Porsche Wiki
http://www.thesaabsite.com/9000/9000transrepair.htm
crumbum is offline   Reply With Quote
