Originally Posted by sincporsche
Removing the back cushion is simple. just put the seatback forward. detach the bottom of the seat back by sliding the bottom anchor bar out. It just pulls straight toward the back of the car. Pull the bottom to the front and lift up on the cushion from the top. It just pops off.
Turn the cushion over and remove the material holding the leather cover. Pull back the sides. This will expose the cross chambers with foam cushioning. Now pull the arm cuff through at the lumbar level leaving the tubing hanging out toward the center console. Reinstall. Your back is good to go.
That's the kind of info I was looking for. Thanks
