Again, read through this board and look at all the little issues this car has, like the foam breaking up on the HVAC doors, the microswitchs for the windows and top, the leaky coolant tanks, the leaking oil cooler, the weak water pump, the leaky aos, the peeling interior parts, the broken or missing roll bar screens, the bad suspension bushings, the worn out wheel bearings, the plugged drain holes shorting out the security system, the bad ignition switches, not to mention the internal engine problems.
Again, if your looking for a care-free owner's experience, look elsewhere.
