Old 12-01-2011, 03:32 PM   #13
JFP in PA
Originally Posted by John99Boxster View Post
JFP...looks like a fun DIY!!
Getting the fill plug out sounds like a bi*&. And removing a side of the diff. cover and possibly axle sounds like a lot to go through.
Could I use a Mighty Vac and suck the fluid out?
Also, what type of fluid/oil do you recommend?
The diff oil is a full synthetic 75W-90 Hypoid gear oil. You will never get all the oil out with a suction system, pulling the side cover is the only way. The process is covered in the Bentley manual if you have access to one..............
