Update on hot start issue.
Sorry for delay in update but have not been home to play with the Boxster for several months.
Anyway replaced the Evaporation Control valve (under the left hand inlet manifold) no chance to check the hot start problem as ambient temp now lower, but still getting the honk from near the filler cap.
BTW its a pig of an assembly to change, one P clip cannot be got at (unless you remove the manifold).
I now suspect that either there is a hole in the evap/fuel filler system somewhere or even a bad seal on the filler cap itself.
Bugman
