Old 09-23-2005, 06:51 AM   #1
SoCal
Originally Posted by SD987
The tire pressure monitoring system (RDK) uses a 433 mhz radio transmitter to relay pressures from each of the four wheels to a processor, which is then integrated into the display. I assume it can be checked using the OBC stalk control.
Where is the sensor, inside the valve stem?
SoCal is offline   Reply With Quote
