Old 11-30-2011, 12:10 PM   #2
Bigsmoothlee
Matt,
Dont even bother touching the other side. With the engine in the car, just pull off the valve cover on the passenger side, set the engine at TDC, remove the cams, turn the engine 360 deg ( just once ), and put the cams back in place. Obviously, you gotta give the engine two turns AFTER reassmbly to make sure the marks line up, just like any other car.
Bigsmoothlee is offline   Reply With Quote
