Old 11-30-2011, 07:37 AM   #3
FNG
I am going to give this a try and will let you know if it corrects the problem. I do belive I set the initial timing wrong, because the procedure that I followed had me set both sets of cams with cylinder 1 on tdc of the compression stroke. I thought that it sounded funny but don't know a great amount about these engine. Learning as I go. I will go to TDC compression stroke on cylinder 1 loosen cams on cylinders 4-6 and than rotate engine 360 degrees and than retighten. If there is anything I am forgetting please let me know, I will get back with you tomorrow to let you know if it worked. Thanks again for the help! Matt
FNG is offline   Reply With Quote
