Originally Posted by fullthrottle52
Johnny,
Check out my garage and you will see the rims and tires. They are 18 in. I thought the 2000 base came with 16 inch so these must have been special ordered or put on my the PO.
I tend to agree with Ghost Rider. Regular dynamic balancing simply is not enough when it comes to larger diameter high performance tires . Try getting them road forced balanced . In the process, you may discover that one or more of your tires is in fact out of "spec" .
Hunter GSP9700 Wheel vibration Control System solves wheel vibration and tire pull problems that balancers and aligners can't fix
Tire Tech Information - Match Mounting to Enhance Tire & Wheel Uniformity
