I had the same issue. I looked closely at the original (bent) rod and measured where the witness mark was on the slot from the washer. I marked it at the same spot on the new rod and set it appropriately. You could also try measuring the position of the other side rod - it's important that they be the same length.
2002 Boxster S, Arctic Silver, 18" Turbo Wheels, 6-speed
