Originally Posted by RDS993
Hello,
I'm researching sway bar kits & Have found the Eibach F&R to be a cost effective option.
The Eibach front is 24mm & the rear is 19mm. The stock S sway bar is 19mm?
Is it worth changing to the rear Eibach sway bar if it is the same size?
Are the Eibach stiffer?.
Also what drop link should I use?
Thanks Rich
I just installed the rear Eibach bar, original drop links in the middle adjustment hole. Big reduction of understeer.
