Originally Posted by milliemax
99 stays hot 24/7 I forget to unplug the radar detector when driving into the garage
Find a fuse that is switched ON with the ignition switch and wire the detector to that?
It's dead easy to find one using a 12v test light or a voltmeter. I have my V-1 wired that was for the same reason so I don't forget it! Gets to be a pita to remember each time you get out of the car to switch off the detector.
Best of luck!
J T
