Old 11-27-2011, 04:20 AM   #15
smshirk
Any time you use a spacer > 10mm, I would recommend using the type that bolt to the hub using the stock bolts and have studs that attach the wheel with supplied lug nuts. HRs are like that as are several other quality hub centric spacers. Extra long bolt attaching spacers are hard on wheel bearings.
2001 Boxster S 3.6, 2003 E46 M3, 94 968 Cab, 80 911 Weissach Edition, BMW 1200 CLS
smshirk is offline   Reply With Quote
