Old 11-26-2011, 07:44 AM   #10
sgt brad
02 box s
check out plx - lcd faces that you can program to look however you want. plugs into the obd port and can read any engine parameter (supposedly, although i've heard that it can't read oil temp for some reason ...). also able to take other signals; presume that it can read the pressure sender output. as far as pods, the only one i've seen is for the steering column (single or double) although there is a thread on 6speed about a guy who used the 'wart' from a 987 sport chrono.
rad---i think the only parameter that obdII doesn't read is oil pressure. go figure. i am certainly not the expert, but that was why i didn't just go with a scan gauge at the very beginning. lmk if you find out something more conclusive since that would be the easiest way to go.
sgt brad is offline   Reply With Quote
