Old 11-25-2011, 10:17 PM   #1
The Radium King
The Radium King's Avatar
check out plx - lcd faces that you can program to look however you want. plugs into the obd port and can read any engine parameter (supposedly, although i've heard that it can't read oil temp for some reason ...). also able to take other signals; presume that it can read the pressure sender output. as far as pods, the only one i've seen is for the steering column (single or double) although there is a thread on 6speed about a guy who used the 'wart' from a 987 sport chrono.
