[/B]
I can assure you that the above mentioned equipment alone will not achieve 20-25 hp . Not at the crank, wheels or otherwise .
Idk. I just looked at the dyno videos for the ECU upgrade and secondary cat bypass pipes from fabspeed motorsports on youtube. They did add roughly 17-20HP with the exhaust and ECU as well as a BMC Air Filter. Was guessing a Evo or Agency Power Cold Air Intake would add 2-3HP more than a BMC performance Air filter so that is how I reached 20-25HP.
As Fabspeed advertises.
8HP and torque for bypass pipes
10-12 HP for ECU Upgrade
Up to 5HP on BMC Filter(my guess is more like 1-2)
