Essentially, all that you need to do is lower the offset to around +45 . With that said, this can be accomplished by adding a 20mm spacer .
p.s. The standard oem lug bolt is 28mm . Therefore, you'll need to source some that are approximately 48mm .
That sound like the plan. Looks like I'll need some matching harware up front.
Do you think this set up will look weird?
p.s.
PORSCHE letter decals for the doors should be here soon.
