Old 11-18-2011, 04:59 PM   #10
Johnny Danger
Johnny Danger's Avatar
Nope everything is stock.
Apparently Wheel Dynamics used to sell the same 18X10 65ET replica wheel along with a hubcentric spacer kit with 17-20mm spacers. I'm checking to see if it comes with longer bolts.
I have no experience with use of spacers on any car really. I tend to stick with OEM but at this point the shipping fees are going to cost me $270 if I can't work something out with the wheel shop (Wheels Plus - L.A.) to take them back and of course no wheels at the end of it all.
Not exactly what I need after a pricey front control arm repair.
Essentially, all that you need to do is lower the offset to around +45 . With that said, this can be accomplished by adding a 20mm spacer .
p.s. The standard oem lug bolt is 28mm . Therefore, you'll need to source some that are approximately 48mm .
