Old 09-21-2005, 06:30 AM   #19
deliriousga
deliriousga's Avatar
Originally Posted by willcapp
Hey,
I've had the same problem now for a while.
I have a 2000. boxster.
I noticed though if I turn on the A/C, the idle fluctuations are minimized...a lot.
I've only noticed it after the car warms up.
During the winter months in Atlanta, I didn't appear to have had the problem.
Also, it doesn't happen every day and I get no dash lights stating there is anything wrong.
I hope this info is useful. If it continues I guess I'll seek the dealer.
Regards,
Will
Where are you in Atlanta? I'd be happy to plug in my AutoTap OBDII program record all of the sensor readings to see what's up. If it's a sensor, it can create the problem but not give any lights because it's still within the limits set by the computer. AutoTap reads each sensor and reports the voltage output or resistance, depending on the sensor. Then you can compare the readings to normal and see what's up.
I'm on the north side (GA 400 corridor) in Cumming. Let me know if you want to get together and I'll try to help if I can.
1966 Wife White/Brown Top
