Originally Posted by 97 Boxster
Just set up my appt with the dealer to get a new key head and have it programmed. OUCH!!
It could be your battery. Change that first. If that doesn't do it, then all you need is new guts to go into your key fob. You don't need a new key cut unless you lose your key. You'll need, if the battery doesn't do it, new insides put into the fob and then have it programmed.
