Old 11-17-2011, 04:21 PM   #10
2003S
2003S's Avatar
Originally Posted by Overdrive View Post
Did you have this key programmed? If not that could be why it's causing that issue. I imagine if you had it programmed it would just act like your regular key and not whack out your alarm. It might be worthwhile to have the programming done if you haven't.
Yeah, I had it programmed, I actually read in the owners manual that this is the designed behavior. I have no idea why, but if you unlock the car with the key, and don't put it in the ignition in 10 seconds, it alarms. Very odd, I'm planning on checking with the dealer if they can disable that behavior.
2003 Midnight Blue S
LN IMS Retrofit
