Old 11-15-2011, 02:49 PM   #1
blue2000s
Porscheectomy
On most cars, if the brake pedal goes to the floor if you hold your foot down, but will work again if you lift off and press on the pedal again, the seals in the master cylinder are leaking. So if you can pump the pedal and get the car to brake again, you need a rebuild of the master cylinder.
If you can't get the brakes to engage no matter how much you pump the pedal, you have a leak in the system somewhere.
In either case, you probably want someone professional to look at it at this point.
