John - the "wires" seldom fault unless eaten out by rodents - they are 12 volt Low Tension.
The normal cause for ignition faults lie with the coilpack itself - usually starting with cracks in the insulation and made worse once moisture gets into the cracks, causing a misfire.
Replace the suspect coilpack and inspect the other 5 - once one has failed, the others seem to follow soon after.
Plus 6 x new coil packs seem to give a decent boost in performance too.....
2001 MV Agusta F4.
