Originally Posted by jaykay
Did they say what the rotor hat material is?? Oem tends to rust a bit. Will the parking brake work with them on rear rotors?
If I am not mistaken, the OEM hat material is cast iron. Whereas the Girodisc's are aluminum. Yes, the parking brake will work with the rear OEM setup.
2003 Porsche Boxster S 3.2L l AASCO Lightweight Flywheel l FVD Brombacher ECU l FVD Brombacher 100 Cell Sport Catalytics l FVD Brombacher Sport Headers l GiroDisc 340mm FR Rotors l IPD Intake Plenum l Litronics l KW Variant 3 Coilovers l Porsche 997 75mm Throttle Body l Road Sport Supply Underdrive Pulley Kit l Sachs Stage 2 Racing Clutch Kit l TechArt Short Shift Kit l TechArt Power Flow Kit l TechArt Sport Exhaust.
