Old 11-13-2011, 07:43 AM   #11
blue2000s
Porscheectomy
Originally Posted by ekam View Post
Yes most car reviews also failed to mention that tire technology have advanced quite a bit. Whatever that they used back in the day are dated and replaced by stickier modern tires.
If you arm a low mileage 993 Turbo with new modern tires I'm sure it can still outrun most new turbos.
All you have to do is look at power to weight to answer that question.
993: 3307lb/400hp=8.27 lb/hp
997: 3487lb/480hp=7.26 lb/hp
The 997 carries around less weight per unit power. It's going to be faster if tires are equal.
