Old 11-11-2011, 11:22 AM   #10
Overdrive
Opposed to Subie Burble
Overdrive's Avatar
Wow, thanks for the write-up Maurice. I'll probably have to read through that a few times just to make sure I've got it all, but hopefully that will work. So am I working all from inside the car to get things disconnected and accessible? So I'll have to pull out the leather storage compartment to do so, right? I don't believe I saw that explicity mentioned, so I wanted to make sure.
As for the window, it sounds like what you're saying makes sense. I can definitely hear the window regulator trying to do what it's supposed to do, but the motion simply isn't there. Funny that the less frequently used door seems to be the one with the stretched connection. Is this something that would require replacement or can I trim off this slack in some way and reconnect it?
-O/D
IMSR + RMS
Robbins glass window top
