Old 11-10-2011, 10:08 AM   #11
Cartel
Originally Posted by ekam View Post
It's lighter because it's got holes in it! j/k! :-)
With GiroDisc you must use 18" wheels and not all 18" wheels will fit.
PFC rotor hats are made of steel and not aluminum. You need to have them coated for winter driving. Other advantage is the rotors are dimpled instead of cross-drilled so the rotors will not crack.
Great information. Thank you for that. Upon glance, the PFC 2-piece rotors look fantastic! In regards to wheel fitment issues, there will not be a discrepancy with the 18" Carrera Lightweights I am running. Nor will there be when it comes time to order Champion RG5's.
2003 Porsche Boxster S 3.2L l AASCO Lightweight Flywheel l FVD Brombacher ECU l FVD Brombacher 100 Cell Sport Catalytics l FVD Brombacher Sport Headers l GiroDisc 340mm FR Rotors l IPD Intake Plenum l Litronics l KW Variant 3 Coilovers l Porsche 997 75mm Throttle Body l Road Sport Supply Underdrive Pulley Kit l Sachs Stage 2 Racing Clutch Kit l TechArt Short Shift Kit l TechArt Power Flow Kit l TechArt Sport Exhaust.
Cartel is offline   Reply With Quote
