Originally Posted by AndyA6
You mentioned the rotors are 340mm vs 317mm, how will they fit?? Caliper brackets change? Please educate me!
Thanks,
Andy
Spot on. They require a 12mm spacer (of which are included in the set) to move the caliper further away from the arm to accomodate the larger rotor. Longer caliper bolts are required and included as well.
2003 Porsche Boxster S 3.2L l AASCO Lightweight Flywheel l FVD Brombacher ECU l FVD Brombacher 100 Cell Sport Catalytics l FVD Brombacher Sport Headers l GiroDisc 340mm FR Rotors l IPD Intake Plenum l Litronics l KW Variant 3 Coilovers l Porsche 997 75mm Throttle Body l Road Sport Supply Underdrive Pulley Kit l Sachs Stage 2 Racing Clutch Kit l TechArt Short Shift Kit l TechArt Power Flow Kit l TechArt Sport Exhaust.
