Old 11-10-2011, 04:22 AM   #2
ppbon
ppbon's Avatar
It's not seized...
... most likely it's being held by the swaybar's tension.
Use a jack to take off the pressure by lifting on the bottom end of the wheel carrier and you should be able to easily pull it out.
Happy Boxstering,
Pedro
Racecar spelled backwards is: Racecar!
ppbon is offline   Reply With Quote
