Originally Posted by The Radium King
can you get oil temp to show on your a/c display? code 1c as per below:
undocumentedacdiagnostics - mikefocke2
othwise, plx sells a lcd gauge that plugs into the obdii port, can read/display multiple parameters at once and has a customisable display. if you google 'boxster gauge pod' you can find a unit that mounts on the steering column quite easily.
Appreciate the tips but both don't work for me
The LCD hack only works for older models
And the oil temp via OBDII is Porsche proprietary, only Durmametric can "read" it. I have a PLX device and it doesn't offer me oil temp as a parameter
