Old 11-08-2011, 07:10 AM   #1
Overdrive
Opposed to Subie Burble
Overdrive's Avatar
Originally Posted by Bengalfan View Post
Thanks for all the answers - especially plugging the exhaust and intakes.
Just don't forget that you put them there. If anything, add some kind of bright/neon colored streamer tags onto them, kind of like the "Remove Before Flight" tags you see on aircraft, just as an added bit of insurance that you won't start the car with a plugged intake and/or exhaust.
One thing with any sort of battery charger/maintainer is that you don't want to ever use them on a frozen battery, so keep ambient temps in mind if there's no sort of temp control involved in your storage. You'll have to let the battery thaw if it's frozen, but if it's already hooked up to maintainer prior to hitting low temps then it shouldn't freeze.
-O/D
IMSR + RMS
Robbins glass window top
