Old 11-07-2011, 07:55 PM   #16
harryrcb
Crazy Austrian
harryrcb's Avatar
Originally Posted by boxster View Post
ive also heard that it hepls if you remove the seal from the bearing.
but wouldn't that make the ball bearings a bit more prone to coming off then?
the seal does not hold the bearing in place. heck it won't even hold the grease in place. I suppose it could help with lubrication. Here is the catch. the only way to get the seal off and do any good, you have to remove the bearing then reinstall it. seems a waste of time to install the same bearing back in the car
Crazy Austrian 007
http://www.ws-ab.com
harryrcb is offline   Reply With Quote
