Old 11-06-2011, 07:36 PM   #10
WhipE350
Autobahn Glanz
WhipE350's Avatar
Originally Posted by Mrmaddbrad View Post
You said you compounded it? Do you use a rubbing compound over the entire car? Or just on the places where the minor scratches are?
Ever try claybarring cars?
Ya forgot to mention, I clay barred before I started. I consider anything with abrasives that break down to be a compound. I call anything with very very minimal abrasives to be a polish. I'm sure others have different definitions. I've used sand paper from 1500 to 3000, and compounds from heavy (abrasives equivalent to ~1200 grit), med, fine, then just a base compound like 3m, Meguiars, Zaino PC (though the Zaino PC is pretty great at removing or rounding most mild swirls, especially if a lubricant is used). All base compounds will milkify especially on black and require careful polishing to remove before waxing. On my 2009 MB I decided to never do it because the swirls were so minor that I didn't feel making the paint slightly milky, though swirl free, was worth it. I use a 6 speed random orbital, it takes more time but works great.
