Chris
Look into whether there is a way to tell if your oil cooler is functioning as it should. I have heard of problems ...rarely though
You may have to play with the oil you are using
Redline water wetter may give you additional cooling assuming your cooling system is working properly...I have it in my car
I think you have the low temp thermostat already
Change or verify that your oil pressure transducer is giving you the right information....what did you do to get it shown in your car?
986 00S
