Originally Posted by aaf006
I also had this problem with my 99 Boxster, turned out to be the convertible top latch microswitch where the dome light is. to test it, id put a knife's blade in the switch to make the contact, if it causes your top to move, its the switch. through pelican parts youre looking at a small 40 part.
thank you!
in the meantime i had to revert the top to manual operation as per the owners manual. how can i put it back on power operation so that i can check what you suggested? any help would be very much appreciated.
