Thread: Oil Starvation
Old 11-04-2011, 09:13 PM   #11
ChrisZang
ChrisZang's Avatar
I have an "S" so unfortunately I have all of ths already ......
But fortunately the engine ain't toast, just my track sessions are usually a little short
Here is a summary of all the things I did so far, unfortunately with only little effect
So here's what I did:
* Replaced water pump
* installed LN engineering low-temp thermostat
* cleaned the radiators (also cleaned between the radiators and the AC condensers)
* switched from 15W50 to 10W40
* bled the coolant system twice
* checked that all the electric fans kick in
* checked pressure on the coolant lines to the front radiators
Originally Posted by Brad Roberts View Post
Heat is the reason the oil pressure is dropping. Waste of time to change out that spring. Add 3rd radiator/BoxsterS water lines to the 2.5 car.
