Old 11-04-2011, 02:40 PM   #10
ddb
www.klisstle.com
ddb's Avatar
Originally Posted by ChairmanRon View Post
I just had this problem pop up with my brand new replacement top. The cable on the driver's side closes outside of the frame. Can you provide any more details on what to look for to correct?
ChairmanRon,
I believe I had the same issue that san rensho describes on my fairly new at the time aftermarket top. Here is a pic of the velcro loop that failed due to the threads coming out of the material. I'm not sure if there was too much tension placed on the loop for some reason or if the thread was poor quality. The top was later replaced due to the glass separating from the top which was an early problem with the some of the early glass-retrofit replacement tops.
There are other reasons for the top to close outside of the frame but this is an easy thing to check. If the loops are attached properly I'm sure some more knowledgeable folks will chime in with other possible causes.
Best of luck,
ddb
