Old 11-04-2011, 12:22 PM   #7
JFP in PA
The Durametric system should be able to read the sensor values in real time if you have one. Without one, you are going to have to test one sensor, doesn't matter which one as they are all throwing the same code, to confirm it is OK. This only requires a volt-ohm meter and access to the diagnostics tree for testing a sensor for voltage, ground source and continuity. If it passes muster, you then need to start checking the wiring from each sensor back to the DME for damage, shorts, loose or damaged connectors, etc. Then test each circuit from each of the four senor ends to the DME connector pin for resistance, continuity, shorts, correct voltages, etc.
