Thread: Radio issue
Old 11-03-2011, 07:16 PM   #10
2003S
2003S's Avatar
Originally Posted by Deserion View Post
I've had the same issue, also on an intermittent basis. My "solution" was to cycle the car on/off, removing the key in between attempts. Then it went back to function.
You sir, win the prize... Haven't used the car since Monday when I had the problem, and was going to check out the fuses, but on your advice, I just started her up, and viola... It's back to normal. Will see if the problem crops up again...
2003 Midnight Blue S
LN IMS Retrofit
