Thread: Boxster weights
Old 11-03-2011, 08:21 AM   #14
Brad Roberts
Brad Roberts's Avatar
I promise I have built the lightest Boxster we will see based on a factory steel tub
1985lbs.. with ABS.. yes it is an obsession and anything under 2300lbs becomes VERY difficult. Yes, it is a dedicated AutoX car, and yes.. I could have easily pulled another 20-30lbs out by getting rid of the stock gas tank and going to fiberglass door skins.. oh.. and getting rid of the big cage in the car.
I believe I can build a 1925lb tub if I start with a bare tub
Insight? I believe you have a Roock conversion car correct? Do you have the cheap Chinese made headers?
B
Brad Roberts is offline   Reply With Quote
