Thread: Boxster weights
Old 11-02-2011, 06:04 PM   #11
Brad Roberts
Brad Roberts's Avatar
oh! you just reminded me: flash to the RoW program with the PST. this disables the secondary air injection system, allowing removal of the valves & the pump. that pump is HEAVY!! the RoW flash will also eliminate the second set of O2 sensors & the clutch start switch.
and makes it run like poo poo.. You can remove the pump and valves without the flash. Porsche sells the factory blockoff plates for $16 (euro cars don't have smog pumps) and our cars only use them during cold start.
I have tried the euro tune multiple times. Unless you "retune" their tune.. it makes less power.
Brad Roberts is offline   Reply With Quote
