Old 10-31-2011, 08:21 PM   #1
Gilles
Originally Posted by violametallic-S- View Post
I hope it is the cooler. But have I done any engine damage?
violametallic...
If your engine is not overheating or puffing white smoke and running smooth you probably will be ok.
Once you replace the oil cooler you may want to fill it up only with water, run the engine, drain fill up again, run the engine, drain, etc, etc, until the water comes clean, then fill it again with destilled water and the proper antifreeze mix.
Think optimistic.. :-)
